Api session event editor overlay set service source
Revision as of 10:18, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set the Service source for a specified Service Overlay. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(OVERLAY Integer ID) |Service Overlay ID | |- |1 |REQUIRED |(SOURCE Integer ID) |Source ID | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_ser...")
0 REQUIRED (OVERLAY Integer ID) Service Overlay ID
1 REQUIRED (SOURCE Integer ID) Source ID
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_service_source/?f=HTML&token=API_TOKEN
with content:
[ 40, 78 ]
