Api session event editor overlay set overlay image
Revision as of 10:18, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Change the image displayed by a specified IMAGE Overlay. The image must be uploaded in the "Overlays" directory. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(OVERLAY Integer ID or multiple values in array [1, 2, 3]) |Overlay IDs (must relate to an IMAGE Overlay) | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"] or matrix [["a", "b"], ["c", "d"], ["e", "f"]]) |Array of Project asset names, omitt...")
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay IDs (must relate to an IMAGE Overlay)
1 REQUIRED (String or multiple values in array ["a", "b", "c"] or matrix [["a", "b"], ["c", "d"], ["e", "f"]]) Array of Project asset names, omitting the directory
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_image/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ [ "A1", "B1" ], [ "A2", "B2" ], [ "A3", "B3" ] ] ]
