Api session event editor overlay set image
Revision as of 10:18, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Change the icon displayed in the navigation window by the Overlay. Only existing overlay project assets are allowed. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(OVERLAY Integer ID or multiple values in array [1, 2, 3]) |Overlay ID | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Project asset name, omitting the directory | |} ===Response Codes=== {|class=wikitable !Response Code: !Descripti...")
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay ID
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Project asset name, omitting the directory
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_image/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Project asset name, omitting the directory 1", "Project asset name, omitting the directory 2", "Project asset name, omitting the directory 3" ] ]
