Api session event editor overlay set discharge method
Revision as of 10:17, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Discharge Method {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(OVERLAY Integer ID) |Overlays | |- |1 |REQUIRED |(Enumeration) |DischargeMethod |HEIGHT_MINIMA, AREAS or WATER_TERRAINS |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_discharge_method/...")
0 REQUIRED (OVERLAY Integer ID) Overlays
1 REQUIRED (Enumeration) DischargeMethod HEIGHT_MINIMA, AREAS or WATER_TERRAINS
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_discharge_method/?f=HTML&token=API_TOKEN
with content:
[ 10, "WATER_TERRAINS" ]
