Api session event editor overlay remove legend entry
Revision as of 10:17, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove the specified legend entries from a specified Overlay. The Overlay must have a custom legend before entries can be removed from it. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(OVERLAY Integer ID) |Overlay ID | |- |1 |REQUIRED |(true, false) |Remove from custom difference legend (false removes the entry from the normal custom legend) |true or false |- |2 |REQUIRED |(Integer number or multiple values in arr...")
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (true, false) Remove from custom difference legend (false removes the entry from the normal custom legend) true or false
2 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Ids of entries which should be removed
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/remove_legend_entry/?f=HTML&token=API_TOKEN
with content:
[ 84, true, [ 1, 2, 3 ] ]
