Api session event editor neuralnetwork set neural network
Revision as of 10:17, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Neural Network {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(NEURAL_NETWORK Integer ID) |Neural Networks | |- |1 |REQUIRED |(byte or multiple values in array [a, b, c]) |byte[] | |- |2 |REQUIRED |(String) |String | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/e...")
0 REQUIRED (NEURAL_NETWORK Integer ID) Neural Networks
1 REQUIRED (byte or multiple values in array [a, b, c]) byte[]
2 REQUIRED (String) String
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorneuralnetwork/set_neural_network/?f=HTML&token=API_TOKEN
with content:
[ 80, [ 1, 2, 3 ], "Text" ]
