Api session event editor netsetting set boolean
API Event to Set Boolean
| 0 | REQUIRED | (Enumeration) | Type | CLUSTER_FRACTION_CONNECTED, CLUSTER_MODELS_ENABLED, ELECTRICITY_ACTIVE, ELECTRICITY_FLOW_ATTRIBUTE, ELECTRICITY_NETWORK_OWNER_ID, FIRST_CONNECT_ACCEPT, GAS_ACTIVE, GAS_FLOW_ATTRIBUTE, GAS_NETWORK_OWNER_ID, HEAT_ACTIVE, HEAT_FLOW_ATTRIBUTE, HEAT_NETWORK_OWNER_ID, INTERNET_ACTIVE, INTERNET_FLOW_ATTRIBUTE, INTERNET_NETWORK_OWNER_ID, LOAD_TO_NODE_LINES_ENABLED, REQUIRE_UTILITY_CORPORATION_APPROVAL, RESTRICT_TO_NET_OVERLAY, SEWER_ACTIVE, SEWER_FLOW_ATTRIBUTE or SEWER_NETWORK_OWNER_ID |
| 1 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editornetsetting/set_boolean/?f=HTML&token=API_TOKEN
with content:
[ "INTERNET_ACTIVE", false ]
