Api session event editor netcluster remove network
Revision as of 10:14, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove Network {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(Enumeration) |NetType |ELECTRICITY, GAS, HEAT, INTERNET or SEWER |- |1 |REQUIRED |(true, false) |Boolean |true or false |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editornetcluster/remove_network/?f=HTML&tok...")
0 REQUIRED (Enumeration) NetType ELECTRICITY, GAS, HEAT, INTERNET or SEWER
1 REQUIRED (true, false) Boolean true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetcluster/remove_network/?f=HTML&token=API_TOKEN
with content:
[ "GAS", true ]
