Api session event editor neighborhood set polygons
Revision as of 10:14, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Polygons {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(NEIGHBORHOOD Integer ID or multiple values in array [1, 2, 3]) |Neighborhoods | |- |1 |REQUIRED |(MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) |MultiPolygon[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Boolean (Content was updated) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: ht...")
0 REQUIRED (NEIGHBORHOOD Integer ID or multiple values in array [1, 2, 3]) Neighborhoods
1 REQUIRED (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) MultiPolygon[]
200 Boolean (Content was updated)
Example POST: https://engine.tygron.com/api/session/event/editorneighborhood/set_polygons/?crs=3857&f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799343.278545872 ], [ 658699.3430634994, 6799343.278545872 ], [ 658699.3430634994, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799396.918280316 ], [ 658777.559833643, 6799396.918280316 ], [ 658777.559833643, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799330.909316098 ], [ 658730.4566386493, 6799330.909316098 ], [ 658730.4566386493, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
