Api session event editor measurement remove
Revision as of 10:13, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove existing [[Measurement]] {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(MEASUREMENT Integer ID or multiple values in array [1, 2, 3]) |[[Measurement]]s | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Boolean (True when at least one item was removed) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editormeasurement/rem...")
0 REQUIRED (MEASUREMENT Integer ID or multiple values in array [1, 2, 3]) [[Measurement]]s
Example POST: https://engine.tygron.com/api/session/event/editormeasurement/remove/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
