Api session event editor measurement import
Revision as of 10:13, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Import multiple [[Measurement]]s {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(GeometryCollection with crs: EPSG:3857) |[[Measurement]]s | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |[[Measurement]] Names | |- |2 |REQUIRED |(OVERLAY Integer ID or multiple values in array [1, 2, 3]) |Overlays | |- |3 |OPTIONAL |(SOURCE Integer ID) |Source (optional) | |} ===Response Codes=== {|c...")
0 REQUIRED (GeometryCollection with crs: EPSG:3857) [[Measurement]]s
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) [[Measurement]] Names
2 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlays
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasurement/import/?crs=3857&f=HTML&token=API_TOKEN
with content:
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799320.123610025 ], [ 658729.9385392354, 6799320.123610025 ], [ 658729.9385392354, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799410.034708745 ], [ 658768.0618857662, 6799410.034708745 ], [ 658768.0618857662, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799351.946437823 ], [ 658736.9856657466, 6799351.946437823 ], [ 658736.9856657466, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "Measurement Name 1", "Measurement Name 2", "Measurement Name 3" ], [ 1, 2, 3 ], "" ]
