Api session event editor measure set requires confirmation
Revision as of 10:13, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set whether the Measure should be confirmed by other Stakeholders. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(MEASURE Integer ID) |Measure ID | |- |1 |REQUIRED |(true, false) |Confirmation Required Boolean |true or false |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/ses...")
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (true, false) Confirmation Required Boolean true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_requires_confirmation/?f=HTML&token=API_TOKEN
with content:
[ 15, false ]
