Api session event editor measure set image
Revision as of 10:13, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set the image of a Measure. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(MEASURE Integer ID or multiple values in array [1, 2, 3]) |Measure IDs | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Image names | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/se...")
0 REQUIRED (MEASURE Integer ID or multiple values in array [1, 2, 3]) Measure IDs
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Image names
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_image/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Image name 1", "Image name 2", "Image name 3" ] ]
