Api session event editor measure set geotiff automatic polygons
Revision as of 10:12, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Let the polygons be calculated automatically based on the GeoTIFFs specified in the GeoTIFF spatial of a Measure. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(MEASURE Integer ID) |Measure ID | |- |1 |REQUIRED |(Integer number) |GeoTIFF Spatial ID | |- |2 |REQUIRED |(true, false) |Automatic calculation |true or false |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300...")
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (Integer number) GeoTIFF Spatial ID
2 REQUIRED (true, false) Automatic calculation true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_geotiff_automatic_polygons/?f=HTML&token=API_TOKEN
with content:
[ 88, 66, false ]
