Api session event editor measure set description
Revision as of 10:12, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set the description of a Measure. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(MEASURE Integer ID) |Measure ID | |- |1 |REQUIRED |(String) |Description | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_description/?f=HTML&token=API_TOKEN with conte...")
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (String) Description
204 No Content
with content:
[ 16, "Description" ]
