Api session event editor measure import buildings
Revision as of 10:12, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Import Measure Building Collection {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(GeometryCollection with crs: EPSG:3857) |Collection of Building geometries | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Building Names | |- |2 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Attribute Names | |- |3 |REQUIRED |(Floating point number or multiple values in array [1.0, 2....")
0 REQUIRED (GeometryCollection with crs: EPSG:3857) Collection of Building geometries
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Building Names
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute Names
3 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Attribute Values
4 REQUIRED (FUNCTION Integer ID or multiple values in array [1, 2, 3]) Functions
5 OPTIONAL (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) Owners (optional)
6 OPTIONAL (MEASURE Integer ID) Set for existing Measure ID (optional)
7 OPTIONAL (Floating point number) Buffer for Points and Lines to make Polygons (optional)
8 OPTIONAL (SOURCE Integer ID) Source (optional)
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editormeasure/import_buildings/?crs=3857&f=HTML&token=API_TOKEN
with content:
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799320.630331624 ], [ 658654.0995043331, 6799320.630331624 ], [ 658654.0995043331, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799450.525887544 ], [ 658749.282000113, 6799450.525887544 ], [ 658749.282000113, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799422.158816084 ], [ 658745.1761840679, 6799422.158816084 ], [ 658745.1761840679, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "Building Name 1", "Building Name 2", "Building Name 3" ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], [ 1, 2, 3 ], "", "", "", "" ]
