Api session event editor measure duplicate
Revision as of 10:11, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Duplicate specified Measures. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(MEASURE Integer ID or multiple values in array [1, 2, 3]) |Measure IDs | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer[] (Integer array) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editormeasure/duplicate/?f=HTML&token=API_TOKEN with co...")
0 REQUIRED (MEASURE Integer ID or multiple values in array [1, 2, 3]) Measure IDs
200 Integer[] (Integer array)
with content:
[ [ 1, 2, 3 ] ]
