Api session event editor global remove point
Revision as of 10:09, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove Point {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(GLOBAL Integer ID) |Globals | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorglobal/remove_point/?f=HTML&token=API_TOKEN with content: <pre>[ 22 ] </pre> {{article end|seealso=*api session event editor...")
0 REQUIRED (GLOBAL Integer ID) Globals
204 No Content
with content:
[ 22 ]
