Api session event editor global add query
Revision as of 10:09, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add Query {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(String) |String | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer (Integer) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorglobal/add_query/?f=HTML&token=API_TOKEN with content: <pre>[ "Text" ] </pre> {{article end|seealso=*api session event editor global}}...")
0 REQUIRED (String) String
200 Integer (Integer)
with content:
[ "Text" ]
