Api session event editor geolink set line buffer
Revision as of 10:07, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Line Buffer {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(GEO_LINK Integer ID or multiple values in array [1, 2, 3]) |Geo Links | |- |1 |REQUIRED |(Floating point number or multiple values in array [1.0, 2.0, 3.0]) |double[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session...")
0 REQUIRED (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) Geo Links
1 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) double[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorgeolink/set_line_buffer/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1.0, 2.0, 3.0 ] ]
