Api session event editor geolink set geometry mode
Revision as of 10:07, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Geometry Mode {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(GEO_LINK Integer ID or multiple values in array [1, 2, 3]) |Geo Links | |- |1 |REQUIRED |(GeometryMode or multiple values in array [a, b, c]) |GeometryMode[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/...")
0 REQUIRED (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) Geo Links
1 REQUIRED (GeometryMode or multiple values in array [a, b, c]) GeometryMode[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorgeolink/set_geometry_mode/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "RADIUS_CENTERPOINT", "RADIUS_CENTERPOINT", "NORMAL" ] ]
