Api session event editor functionoverride duplicate
Revision as of 10:06, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Duplicate existing Functionoverride {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(FUNCTION Integer ID or multiple values in array [1, 2, 3]) |Functions | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer[] (Integer array) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorfunctionoverride/duplicate/?f=HTML&token=API_...")
0 REQUIRED (FUNCTION Integer ID or multiple values in array [1, 2, 3]) Functions
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editorfunctionoverride/duplicate/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
