Api session event editor eventbundle set event
Revision as of 10:06, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Event {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(EVENT_BUNDLE Integer ID) |Event Bundles | |- |1 |REQUIRED |(true, false) |Boolean |true or false |- |2 |REQUIRED |(CodedEvent) |CodedEvent | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editoreventbundle/set_eve...")
0 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundles
1 REQUIRED (true, false) Boolean true or false
2 REQUIRED (CodedEvent) CodedEvent
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoreventbundle/set_event/?f=HTML&token=API_TOKEN
with content:
[ 81, false, {
 "id" : -1,
 "parameters" : [ ]
