Api session event editor eventbundle set description
Revision as of 10:06, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Description {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(EVENT_BUNDLE Integer ID) |Event Bundles | |- |1 |REQUIRED |(String) |String | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editoreventbundle/set_description/?f=HTML&token=API_TOKEN with content: <pre>[ 88,...")
0 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundles
1 REQUIRED (String) String
204 No Content
with content:
[ 88, "Text" ]
