Api session event editor cinematic set keypoint orientation
API Event to Set Keypoint Orientation
| 0 | REQUIRED | (CINEMATIC_DATA Integer ID) | Cinematic Datas | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Float[] | |
| 3 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Float[] | |
| 4 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Float[] |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_orientation/?f=HTML&token=API_TOKEN
with content:
[ 18, 83, [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ] ]
