Api session event editor cinematic remove keypoint event bundle
Revision as of 10:05, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove Keypoint Event Bundle {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(CINEMATIC_DATA Integer ID or multiple values in array [1, 2, 3]) |Cinematic Datas | |- |1 |REQUIRED |(Integer number or multiple values in array [1, 2, 3]) |Integer[] | |- |2 |REQUIRED |(Integer number or multiple values in array [1, 2, 3]) |Integer[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content...")
0 REQUIRED (CINEMATIC_DATA Integer ID or multiple values in array [1, 2, 3]) Cinematic Datas
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
2 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorcinematic/remove_keypoint_event_bundle/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ 1, 2, 3 ] ]
