Api session event editor cinematic add keypoint event bundle
Revision as of 10:05, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add Keypoint Event Bundle {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(CINEMATIC_DATA Integer ID) |Cinematic Datas | |- |1 |REQUIRED |(Integer number) |Integer | |- |2 |REQUIRED |(EVENT_BUNDLE Integer ID) |Event Bundles | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session...")
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic Datas
1 REQUIRED (Integer number) Integer
2 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundles
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_event_bundle/?f=HTML&token=API_TOKEN
with content:
[ 97, 95, 50 ]
