Api session event editor cinematic add
Revision as of 10:05, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add new Cinematic {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholders | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer (Integer) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorcinematic/add/?f=HTML&token=API_TOKEN with content: <pre>[ 81 ] </pre> {{article end|seealso=*api sessi...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
200 Integer (Integer)
with content:
[ 81 ]
