Api session event editor building set decals
Revision as of 10:05, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Decals {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(BUILDING Integer ID) |Buildings | |- |1 |REQUIRED |(Enumeration) |FaceType |BASEMENT, EXTRA, GROUND, ROOF or TOP |- |2 |OPTIONAL |(Floating point number or multiple values in array [1.0, 2.0, 3.0]) |float[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST:...")
0 REQUIRED (BUILDING Integer ID) Buildings
1 REQUIRED (Enumeration) FaceType BASEMENT, EXTRA, GROUND, ROOF or TOP
2 OPTIONAL (Floating point number or multiple values in array [1.0, 2.0, 3.0]) float[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/set_decals/?f=HTML&token=API_TOKEN
with content:
[ 83, "EXTRA", "" ]
