Api session event editor building import
API Event to Import Building Collection
| 0 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | Collection of Building geometries | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Building Names | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attribute Names | |
| 3 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | Attribute Values | |
| 4 | REQUIRED | (FUNCTION Integer ID or multiple values in array [1, 2, 3]) | Functions | |
| 5 | REQUIRED | (Integer number or multiple values in array [1, 2, 3]) | Owners | |
| 6 | OPTIONAL | (Floating point number) | Buffer for Points and Lines to make Polygons (optional) | |
| 7 | OPTIONAL | (SOURCE Integer ID) | Source (optional) |
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/import/?crs=3857&f=HTML&token=API_TOKEN
with content:
"type" : "GeometryCollection",
"geometries" : [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799378.893782711 ], [ 658694.2302830761, 6799378.893782711 ], [ 658694.2302830761, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799302.053808507 ], [ 658779.8726034408, 6799302.053808507 ], [ 658779.8726034408, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799409.805707025 ], [ 658720.084905554, 6799409.805707025 ], [ 658720.084905554, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "Building Name 1", "Building Name 2", "Building Name 3" ], [ "Attribute Name 1", "Attribute Name 2" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ], [ 7.0, 8.0 ], [ 9.0, 10.0 ], [ 11.0, 12.0 ] ], [ 1, 2, 3 ], [ 1, 2, 3 ], 0.5, "" ]
