Api session event editor building add geometry
Revision as of 09:54, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add a custom building geometry {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(BUILDING Integer ID or multiple values in array [1, 2, 3]) |Building ID | |- |1 |REQUIRED |(CUSTOM_GEOMETRIE Integer ID or multiple values in array [1, 2, 3]) |Custom Geometry ID | |- |2 |REQUIRED |(boolean or multiple values in array [a, b, c]) |Primary building for geometry | |- |3 |OPTIONAL |(SOURCE Integer ID) |Source (optional) | |} ==...")
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building ID
1 REQUIRED (CUSTOM_GEOMETRIE Integer ID or multiple values in array [1, 2, 3]) Custom Geometry ID
2 REQUIRED (boolean or multiple values in array [a, b, c]) Primary building for geometry
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/add_geometry/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ true, false, true ], "" ]
