Api session event editor building add polygons
Revision as of 09:54, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add polygons for Building Section. In case the building is empty, optionally set ownership to largest Plot Owner of provided MultiPolygon {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(BUILDING Integer ID or multiple values in array [1, 2, 3]) |Building ID | |- |1 |REQUIRED |(Integer number or multiple values in array [1, 2, 3]) |Section ID | |- |2 |REQUIRED |(MultiPolygon with crs: EPSG:3857 or multiple values i...")
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building ID
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Section ID
2 REQUIRED (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) MultiPolygon
3 REQUIRED (true, false) Use largest Owner true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/add_polygons/?crs=3857&f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799417.794785002 ], [ 658688.1592623573, 6799417.794785002 ], [ 658688.1592623573, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799300.374485122 ], [ 658673.9870508023, 6799300.374485122 ], [ 658673.9870508023, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799325.640705583 ], [ 658714.8080873851, 6799325.640705583 ], [ 658714.8080873851, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
} ], false ]
