Api session event editor attributeaction duplicate
Revision as of 09:54, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Duplicate existing Attributeaction {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(ATTRIBUTE_ACTION Integer ID or multiple values in array [1, 2, 3]) |Attribute Actions | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer[] (Integer array) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorattributeaction/duplicate/?f=HTML&...")
0 REQUIRED (ATTRIBUTE_ACTION Integer ID or multiple values in array [1, 2, 3]) Attribute Actions
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editorattributeaction/duplicate/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
