How to adjust the Unit System of a project
Revision as of 13:33, 5 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "The Unit System of a project is normally configured when creating a new project. However, it is also possible to adjust the Unit System for existing projects. {{howto |Open the project in the editor. |Select the Tools tab in the ribbon bar. |Click on the API Overview button |Navigate to Events ... EditorSetting ... SET_UNIT_SYSTEM_TYPE |Select the desired Unit System in the choice box |Click on POST Form to change the unit system }}")
How to adjust the Unit System of a project:
  1. Open the project in the editor.
  2. Select the Tools tab in the ribbon bar.
  3. Click on the API Overview button
  4. Navigate to Events ... EditorSetting ... SET_UNIT_SYSTEM_TYPE
  5. Select the desired Unit System in the choice box
  6. Click on POST Form to change the unit system
