Log in
Once the Tygron Platform application has successfully installed, the login screen appears.
Log-in screen
How to log in to the Tygron Platform
To use the Tygron Platform you need to login. After logging in you get access to the Tygron Platform and can start working on your projects. You need a username and a password before you can login. You can sign up for an account on our website.
After entering your credentials, select the 'SIGN IN' button to proceed to the main menu.
Automatically logging in
If you need to login often on the same system, you can select to save your password. You should be aware, that if you select this option, anyone who accesses the Tygron Platform on your computer, has access to your account and project(s) without having to enter your log-in credentials. Also please note that this setting will expire after a set period (default 1 week).
Automatic login check box
Reset lost password
In case you have lost your password:
- You can reset your password by selecting the "Forgot password?" option at the login panel.
- After login you will be asked to change the temporary password into a new password.
- This password must contain a minimum amount of characters. You will get feedback when this is not the case.
- As an additional safety measure the password must also not be too simple, e.g. "welcome2026" or "password123" both may have enough characters but are deemed very unsafe and cannot be used. In this case you will get an error message "Unsafe or too simple password".
- Try typing a different password until it is accepted.
- You can now login using the new updated password.
Request password reset
Enter user email address
Unsafe or too simple password error
Logged in
Once logged in you can:
- Create a new project
- Start editing existing projects, including Demo projects.
- Manage your user account
