Water Module Changes
Revision as of 16:30, 3 December 2025 by Maxim@tygron.com (talk | contribs) (Created page with "This page describes the changes between the Water Module LTS 2024 -> LTS 2026. These changes will result in a faster en more realistic result, but can be reversed for full backwards compatibility. ==Updates== The Water Module 2026 has several changes, most changes only make it faster or contain additional functionality. The changes listed here can also change the outcome. * Polygon rasterization. * Minimal saturation Unsaturated Zone. * Drainage height (in relation to...")
Updates
  • Polygon rasterization.
  • Minimal saturation Unsaturated Zone.
  • Drainage height (in relation to surface).
Revert
  • Rasterization: Switch to "outline" mode in the Calculation Popup.
  • Minimal saturation: Set attribute [[MI
