Version 2025.8.0
Revision as of 08:34, 2 September 2025 by Frank@tygron.nl (talk | contribs)
Version 2025.8.0 is released on preview.tygron.com on September 5th 2025.
Geo Data
  • Added support for the smartBUILD Industry Foundation Classes (IFC) format.
  • Added support for the GeoPackage format.
  • DXF and IFC can now also be re-positioned when they miss Geo-coordinates.
Scenario
  • Starting a new Scenario no longer recalculates base map, saving time.
  • Added option to only calculate the Scenario where the measures are applied as limit map.
  • Active Scenario attributes and description remain persistent when stopping the testrun (for comparisons).
  • Added simple panel example that calculates all Scenarios Indicator scores for comparison.
  • Added new TQL Selection to query the active Scenario and Overlay showing limit map.
SimCore
  • Improved rasterization that matches original building polygons better.
  • Significant speedup for TQL Queries and rasterization.
  • Added TQL query SELECT indicator score to combine indicators.
  • Updates to e.g. area attributes can now also be used in indicator calculations.
  • Added TQL X-Query support for Text Panels.
  • SimCore Overview panel now shows performance per step as explained on WIKI.
Other
  • Water: Fix proper naming for Plant Transpiration and Surface Evaporation.
  • Added new Floors option in Heightmap Overlay.
  • Deprecated: Indicator history and Vacancy Overlay.
  • Several optimizations and bugfixes for limit map calculations.
  • Updated underlying polygon calculations.
  • Several smaller bug fixes, security updates and WIKI Updates.
