Version 2025.7.0
Version 2025.7.0 is released on preview.tygron.com on July 4th 2025.
Updates
  • 3D models outside the project map can now be positioned manually in wizard.
  • Added new calibration step to Water Wizard to globally tune key coefficients.
  • Update now always recalculates the entire map, this fixes several smaller issues.
  • Update logo is updated and works correctly again (red mark when update is needed).
  • Action menu popup has ability to open panels directly, also supported in web viewers.
  • Default CSS is now only applied when a text/excel panels has no <style> tag.
  • Water overlay output attributes now retain default name for single overlay projects.
  • Improved attribute loading in Geo Wizard.
  • OpenStreetMap is now default background for new project selection.
  • Bugfix for retrieving projects from archive and added option to trash in archive.
  • Bugfix for default user nickname, that can break user name changes.
  • Bugfix for initial selection polygon in Client.
  • Added warning when DPRA heat overlay cell size does not match designed size.
  • Removed previously deprecated Aerius and Waterwijzer Overlays.
  • Improved server stability when at max capacity.
  • Several smaller bug fixes, security updates and WIKI Updates.
