Template:Shade calculation model
Revision as of 10:53, 13 February 2025 by Frank@tygron.nl (talk | contribs)
The shade is dependent on the location of the sun. This in turn is dependent on the [[Dates ({{{1}}})|date and the time of day]] and the world location of the project.
Since each timeframe result of a [[{{{1}}}]] is related to a particular date and time of day, each time frame will have a related [[Sun altitude ({{{1}}})|sun altitude]] and [[Sun azimuth ({{{1}}})|sun azimuth angle]]. These angles are calculated automatically based on the world location of your project and the [[Dates ({{{1}}})|date]] of the timeframe.
Once the sun angles and the building, terrain and foliage height are known, whether the cell is shaded or not is computed as follows for each cell:
  1. Travel away from the cell in the direction of the sun azimuth angle.
  2. For each cell traversed this way, calculate the height of the sun ray based on the altitude angle.
  3. Compare the sun ray altitude with the maximum height (terrain, building and foliage) at the traversed cell.
    1. If the surface height in the traversed cell higher, the cell is shaded and we can stop.
    2. If the sun ray altitude in the traversed cell is higher, the calculation is performed again for the next traversed cell.
    3. If all cells are traversed and the computation didn't stop in any cell, the cell can be reached by direct sunlight and the cell is not shaded.
  • Shade calculations are based on the heights of Buildings starting from the ground. When a Buildings references to a Custom Geometry, for any grid cell a building is considered solid all the way from the ground up to the highest part of the Custom Geometry within that grid cell. This allows for detailed roofs, shadows, and tapering shapes, but will not include holes within the height of the building, such as spaces under balconies. The exact interpreted heights can be inspected via a Digital Surface Model Overlay.
  • This model uses a maximum ray testing range, which can be configured using the [[Max shadow distance ({{{1}}})|MAX_SHADOW_DISTANCE]]. This setting can be configured with a values between 100 m and 1000 m. This also means that calculated shadows cannot potentially be larger than the configured distance. The maximum shadow distance has no effect on the orientation of the shade.
  • [[Shade result type ({{{1}}})]]
