How to adjust a Neural Networks metadata
Revision as of 13:37, 19 December 2024 by Frank@tygron.nl (talk | contribs)
Metadata of a Neural Network stored in the ONNX file format can be adjusted using the python code found below.
Prerequisites
An installed python environment is required to execute the code. Additionally, install the onnx library using PIP:
pip install onnx
Add a metadata key (without duplication):
def addMeta(onnx_model, key, value):
    for entry in onnx_model.metadata_props:
        if entry.key == key:
            entry.value = value
            return
    meta = onnx_model.metadata_props.add()
    meta.key = key
    meta.value = value
import onnx
onnx_model = onnx.load("path/to/onnx/file")
addMeta(onnxModel, "key", "value")
Save the onnx model to file:
with open(onnxFilePath, "wb") as f:
    f.write(onnx_model.SerializeToString())
Producer, version and description are set using these functions
def setProducer(onnxModel, producer):
    onnxModel.producer_name = producer
def setModelVersion(onnxModel, modelVersion):
    onnxModel.model_version = modelVersion
def setDocString(onnxModel, description):
    onnxModel.doc_string = description
