How to adjust a Neural Networks metadata
Revision as of 12:48, 19 December 2024 by Frank@tygron.nl (talk | contribs)
Required install:
pip install onnx
Add a metadata key (without duplication):
def addMeta(onnx_model, key, value):
    for entry in onnx_model.metadata_props:
        if entry.key == key:
            entry.value = value
            return
    meta = onnx_model.metadata_props.add()
    meta.key = key
    meta.value = value
import onnx
onnx_model = onnx.load("path/to/onnx/file")
addMeta(onnxModel, "key", "value")
Save the onnx model to file:
with open(onnxFilePath, "wb") as f:
    f.write(onnx_model.SerializeToString())
Producer, version and description are set using these functions
def setProducer(onnxModel, producer):
    onnxModel.producer_name = producer
def setModelVersion(onnxModel, modelVersion):
    onnxModel.model_version = modelVersion
def setDocString(onnxModel, description):
    onnxModel.doc_string = description
