Template:Drainage variants reference
Revision as of 17:14, 11 December 2024 by Frank@tygron.nl (talk | contribs) (Created page with "* Passive Drainage lets water flow from the drainage pipes into the waterway. * Active Drainage with a negative Q can pump water from from the waterway (with a lower level) into the drainage pipes. * Active Drainage with a positive Q can pump water from the drainage pipes up into a waterway (with a higher level).")
