CesiumJS complete code
Revision as of 13:34, 4 March 2024 by Frank@tygron.nl (talk | contribs)
The page contains the complete code that can be run in Cesium Sandcastle: []
// Constants
const dim = 128;
const minLevel = 6;
const maxLevel = 19;
const tilepx = 512;
const TOKEN = ""; // IMPORTANT: Place here the project session token between the ""
const BGCOLOR = "1f1f00"; // ff0000 is red, hexadecimal color
const SHADOW = true; //true ,false
const BASEMAP_INDEX = 0; // SATELLITE=0, TOPOGRAPHIC=1 and GRAY=2.
const STYLE = "COLORED"; // WHITE, COLORED
const SPACING = 10;
const TEXTURE = "MEDIUM"; // SMALL, MEDIUM , LARGE
const FEATURE_ID = "ID";
const BASEURL = "https://engine.tygron.com/web/";
// Construct the default list of terrain sources.
var terrainModels = [];
terrainModels.push(new Cesium.ProviderViewModel({
name: "Project Terrain",
category: "Terrain",
tooltip: "",
iconUrl: Cesium.buildModuleUrl('Widgets/Images/TerrainProviders/Ellipsoid.png'),
creationFunction: function () {
return new Cesium.CustomHeightmapTerrainProvider({
width: dim,
height: dim,
maximumLevel: maxLevel,
callback: function (x, y, level) {
if (level <= 10) { // ignore zoom levels 10 and lower
return new Float32Array(dim * dim); // all zeros
const test = Cesium.Resource.fetchArrayBuffer(BASEURL+'terrain/' + level + '/' + x + '/' + y + '.bin?worlddatum=true&token='+TOKEN+'&width=' + dim + '&height=' + dim);
return test.then(function (buffer) {
const array = new Float32Array(dim * dim); // all zeros
const view = new DataView(buffer);
for (let i = 0; i < dim * dim; i++) {
array[i] = view.getFloat32(i * 4);
return array;
var imageryViewModels = [];
const baseMaps = ["SATELLITE", "TOPOGRAPHIC", "GRAY"];
for (let i = 0; i < baseMaps.length; i++) {
imageryViewModels.push(new Cesium.ProviderViewModel({
category: "Base Map",
tooltip: "",
return new Cesium.WebMapServiceImageryProvider({
url: BASEURL+'wms',
layers: baseMaps[i],
tileHeight: tilepx,
tileWidth: tilepx,
getFeatureInfoFormats: [new Cesium.GetFeatureInfoFormat("json", "application/json")],
proxy: new Cesium.DefaultProxy('/proxy/'),
parameters: {
crs: "4326",
forcexy: "true",
bgcolor: BGCOLOR,
walled: "false",
token: TOKEN
getFeatureInfoParameters: {
crs: "4326",
forcexy: "true",
token: TOKEN,
// Construct the viewer, with a high-res terrain source pre-selected.
var viewer = new Cesium.Viewer('cesiumContainer', {
terrainProviderViewModels: terrainModels,
selectedTerrainProviderViewModel: terrainModels[0],
imageryProviderViewModels: imageryViewModels,
selectedImageryProviderViewModel: imageryViewModels[BASEMAP_INDEX],
animation: false,
timeline: false,
homeButton: false,
navigationHelpButton: false,
navigationInstructionsInitiallyVisible: false,
fullscreenButton: false,
shadows: SHADOW,
var neighborhoodUrl = new Cesium.Resource({
url: BASEURL+"neighborhoods.geojson",
queryParameters: {
token: TOKEN,
crs: "4326",
forcexy: "true",
var data = await neighborhoodUrl.fetchJson();
var labels = data.features;
for (var i = 0; i < labels.length; ++i) {
var p = labels[i];
var longitude = p.geometry.coordinates[0];
var latitude = p.geometry.coordinates[1];
var height = p.geometry.coordinates[2] == null ? 200 : p.geometry.coordinates[2] + 200;
var id = p.properties[FEATURE_ID];
const entity = viewer.entities.add({
position: Cesium.Cartesian3.fromDegrees(longitude, latitude, height),
label: {
text: p.properties.name,
font: "12pt arial",
style: Cesium.LabelStyle.FILL_AND_OUTLINE,
outlineWidth: 2,
verticalOrigin: Cesium.VerticalOrigin.TOP,
fillColor: Cesium.Color.WHITE,
/* Overlay Variables */
var overlayLayer = null;
const activateOverlay = function(overlayID, timeframe, difference){
const provider = new Cesium.WebMapServiceImageryProvider({
url: BASEURL+'wms',
layers: overlayID,
tileHeight: tilepx,
tileWidth: tilepx,
parameters: {
crs: "4326",
forcexy: "true",
token: TOKEN,
timeframe: timeframe,
styles: difference ? "DIFFERENCE" : "",
crs: "4326",
forcexy: "true",
token: TOKEN,
viewer.imageryLayers.remove(overlayLayer);
var newOverlayLayer = new Cesium.ImageryLayer(provider, { minimumTerrainLevel: minLevel });
viewer.imageryLayers.add(newOverlayLayer);
if (overlayLayer !== null) {
overlayLayer.destroy();
overlayLayer = newOverlayLayer;
const start = async function () {
var tileset = await Cesium.Cesium3DTileset.fromUrl(BASEURL+'3dtiles/tileset.json?token='+TOKEN+'&style='+STYLE+'&spacing='+SPACING+'&texture='+TEXTURE);
viewer.scene.primitives.add(tileset);
var boundingSphere = tileset.root.boundingVolume._boundingSphere;
viewer.camera.viewBoundingSphere(tileset.root.boundingVolume._boundingSphere);
viewer.camera.flyToBoundingSphere(tileset.root.boundingVolume._boundingSphere);
activateOverlay(1, 0, false);
start();
