How to convert a DWG to GeoJSON
Revision as of 13:41, 30 January 2024 by Frank@tygron.nl (talk | contribs)
This article is a stub.
DWG, which is a CAD file, is an often used format for the design and exchange of urban development plans. However, as it is not an open standard, the Tygron Platform cannot import it directly. Instead, it is necessary to convert to a different format which can be imported.
Template:Editor steps
  • The latest version of QGIS is verified to work with DWG versions up to DWG2013. Newer version may not load properly or at all.
  • To see whether the correct parts of the plan are included, do not select the "Merge Layers" option while importing the DWG. This will show features on their individual layers, making it easier to verify whether any and all correct data is selected. It is then possible to reimport the DWG into QGIS with the layers merged.
