Building elevation prequel (Heat Stress Overlay)
Revision as of 14:45, 23 January 2024 by Frank@tygron.nl (talk | contribs) (Created page with "{{Overlay prequels|overlay=Heat|allowselflinks=true| <onlyinclude>{{Overlay prequels|type=row|overlay=Heat |prequel=BUILDING_ELEVATION |name=Building elevation |unit=m |description=Used for initializing the digital surface model used for this Heat Overlay. |min=-10000 |max=10000 }}</onlyinclude> }} {{article end |notes=* The values in this prequel grid are clamped between 0 and the maximum float value. No data values are not allowed, although negative no dat...")
  • The values in this prequel grid are clamped between 0 and the maximum float value. No data values are not allowed, although negative no data values will result in a foliage height of 0.
  • The foliage height is a relative height value in meters. Not the datum height.
