How to create a Basic Mode Project
Revision as of 13:42, 2 October 2023 by Rudolf@tygron.nl (talk | contribs) (Created page with "For some Projects, especially at more broad regional levels, the Basic Mode may provide more appropriate performance while still being well-suited for a broad range of use-cases and calculations. However, the choice for the creation of a Basic Mode Project must be made at the time of Project creation. {{editor location steps|mode=Main menu|New Project}} {{howto|title=create a Basic Mode Project | In the main menu, opt to c...")
Main menu → New Project
How to create a Basic Mode Project:
  1. In the main menu, opt to create a new Project.
  2. Enter the name for the Project as usual.
  3. For the Detail level, select Basic.
  4. Click on "Create new Project", and progress through the rest of the Project creation process as usual.
  • Creating a Basic Mode Project is
  • When using a Project Template to create a new Project with, the new Project will inherit its Detail level from the Project Template. A Template Project which is not a Basic Mode Project will result in a new Project which is not a Basic Mode Project. A Template Project which is a Basic Mode Project will always result in a new Project which itself is also a Basic Mode Project.
