TQL
Please note: This page is currently being updated!
TQL
The Tygron Query Language is a special-purpose programming language designed for obtaining spacial area information from a specific game session on the Tygron Engine. The primary reason for its development was to make an easy to use bridge between the Tygron Engine and Microsoft Excel.
Queries
The operation used in TQL is the query, which is performed with the declarative SELECT statement. SELECT retrieves data from a running Tygron game session. The SELECT statements have no persistent effects on the game session itself.
Queries allow the user to describe desired data, leaving the Tygron Engine responsible for planning, optimizing, and performing the physical operations necessary to produce that result as it chooses.
A query includes a parameter to include in the final result, immediately following the SELECT keyword. Currently, one of the following result parameters can be chosen:
Result Parameter Description Example
FLOORSIZE Floor size of buildings. SELECT_FLOORSIZE_WHERE_CATEGORY_IS_OFFICES
LOTSIZE Lot size of buildings. SELECT_LOTSIZE_WHERE_CATEGORY_IS_OFFICES
UNITS Amount of housing units. SELECT_UNITS_WHERE_CATEGORY_IS_SOCIAL
DIKES Surface space of constructed dikes or levees. SELECT_DIKES_WHERE_ZONE_IS_1
Comparison Predicate and Clauses
The SELECT and result parameter are followed by the WHERE statement. The WHERE statements includes a comparison predicate, which restricts the information taken into account by the query. The WHERE clause eliminates all information from the result set where the comparison predicate does not evaluate to True.
The comparison predicate consists of 0 or more clauses. Clauses consists of three parts;
  • Clause Type
  • Operator
  • Value
The clause types and expected values currently supported are:
Clause Type Description Value Type Example
CATEGORY Function category type, see Function CATEGORY_IS_OFFICES
Operators
TQL clausses currently support the following Operators:
Operator Description Example
IS Equal to CATEGORY_IS_OFFICES
