Install
An installer is a software component used for the installation, maintenance, and removal of the Tygron Platform software.
What is the function of the installer in relation to the Tygron Platform?
- The Tygron Platform is an application which needs to be installed on a local machine. The installer guides users through this process, ensuring easy setup.
Downloading the installer
- Before you can install the Tygron Platform (LTS) you first need to download the installer.
How to Download the installer for the Tygron Platform (LTS):
- Open your browser
- open https://engine.tygron.com/
- Select "Windows (64 bit) Installer"
- "TygronEngineWin64.msi" will start downloading
- Once the download has been completed proceed to the next step, "Running the installer"
- Before you can install the Tygron Platform (Preview) you first need to download the installer.
How to Download the installer for the Tygron Platform (Preview):
- Open your browser
- open https://preview.tygron.com/
- Before you can use the Tygron Platform you first need to run the installer.
How to Install the Tygron Platform:
- Open "TygronEngineWin64.msi"
- the installer will install the Tygron Platform Application
- A desktop shortcut and a start-menu shortcut will be created
1. Application being installed
2. Installing successfully completed
3. The desktop shortcut to be used to launch the Tygron Platform
Once the installer has completed you can launch the Tygron Platform. See the following page to learn how to log in.
