Install
An installer is a software component used for the installation, maintenance, and removal of the Tygron Platform software.
What is the function of the installer in relation to the Tygron Platform?
- The Tygron Platform is an application which needs to be installed on a local machine. The installer guides users through this process, ensuring easy setup.
Downloading the installer
- Before you can install the Tygron Platform (LTS) you first need to download the installer.
How to Download the installer for the Tygron Platform (LTS):
- Open your browser
- open https://engine.tygron.com/
- Select "Windows (64 bit) Installer"
- "TygronEngineWin64.msi" will start downloading
- Once the download has been completed proceed to the next step, "Running the installer"
- Before you can install the Tygron Platform (Preview) you first need to download the installer.
How to Download the installer for the Tygron Platform (Preview):
- Open your browser
- open https://preview.tygron.com/
- Before you can use the Tygron Platform you first need to run the installer.
How to Install the Tygron Platform:
- Open "TygronEngineWin64.msi"
- the installer will install the Tygron Platform Application
- A desktop shortcut and a start-menu shortcut will be created
1. Application being installed
2. Installing successfully completed
3. The desktop shortcut to be used to launch the Tygron Platform
Launching the Tygron Platform
- Once the installer has completed you can launch the Tygron Platform.
How to Start the Tygron Platform:
- Launch "Tygron Platform" from the desktop shortcut or the start menu
- You will be prompted with the login screen.
1. Login screen, prompted when Application has been launched
