Setting
Revision as of 14:05, 10 February 2023 by Frank@tygron.nl (talk | contribs)
Setting is an item that stores configuration properties of your project.
List of available settings
| Name | Default value | Description |
| ACTIVE_SCENARIO | 0 | Stores the id of the active scenario. |
| AREA_GROUPS | Used to store Area attribute filters | |
| AUTO_CALCULATION | true | Whether changes made to the project automatically trigger a recalculation of a project. |
| BASE_PANELS | HOVER_PANEL NAVIGATION_PANEL TOPBAR_PANEL LEFT_MENU_PANEL FEEDBACK_PANEL | Panels that are considered base panels in the Template:User Interface |
| CAMERA_SPEED | NORMAL | Camera Speed (SLOW, NORMAL) |
| CURRENCY | EURO | Currency that is used in your project. |
| CUSTOM_DATA_SERVICE | My own CSW service | |
| DECIMALS | 6 | Decimal accuracy used in attributes and function values |
| DEFAULT_GROUNDPRICE_M2 | 400 | Default price of one m2 ground in euro |
| DEFAULT_GROUND_LOWER_PRICE_M3 | 50 | Default price in EUR to lower one m3 ground |
| DEFAULT_GROUND_RAISE_PRICE_M3 | 50 | Default price in EUR to raise one m3 ground |
| DETAILED | true | High detail project. |
| EXPORT_CRS | EPSG:3857 | The default export CRS for your project for situations in the Tygron Platform where it currently cannot be selected. |
| GRID_CELL_SIZE_M | 2 | Grid cell size in meters, default is 2 |
| IMPORT_CRS | The last selected import CRS, selected automatically for files imported into your project in the Tygron Platform | |
| IMPORT_CRS_FORCE_XY | true | The last selected import "force xy" (=longitude first) option, selected automatically for files imported into your project in the Tygron Platform |
| LIMIT_MAP | MULTIPOLYGON EMPTY | The geometry that is used to limit the data obtained during New Project generation. |
| MAP_SIZE_M | 0 0 | Map size in X and Y in meters, default 0 (no map) |
| MAX_TOTAL_GRIDCELLS | 0 | Used to communicate the maximum amount of grid cells that your project can support. |
| MEASUREMENT_SYSTEM_TYPE | SI | |
| MIN_CELL_M | 0 | Minimum cell size in meters |
| MODEL_STYLE | TEXTURED | The model style of the building's in the 3D Visualization. |
| PROJECT_NAME | Project Name | The Project's name |
| RECALCULATION_REQUIRED | false | A setting that is set by the Tygron Platform to indicate this project required a recalculation. |
| RECENT_CRSS | EPSG:3857 EPSG:28992 | |
| REGION | NORTHWESTERN_EUROPE | |
| RESERVED_LAND | MULTIPOLYGON EMPTY | |
| SATELLITE_BRIGHTNESS | -1 | |
| SATELLITE_COLOR | ||
| SATELLITE_FILE_NAME | default | |
| SCHEDULED_UPDATE | ||
| SCHEDULED_UPDATE_MAIL | ||
| SCHEDULED_UPDATE_SMS | ||
| SDK_ACCESS | false | Currently not used |
| SECTOR_SIZE_M | 500 | |
| SHOW_ACTION_LOG | true | |
| SHOW_BUILDING_AND_MEASURE_POPUP | false | |
| SHOW_WATER_POPUP | false | |
| SKY_TYPE | DEFAULT | |
| SOLAR_PANEL_POSITION | 0.0 -0.5 -1.0 | |
| STATE | NOTHING | |
| SUN_DATES | ||
| SUPER_USER_MESSAGE | ||
| SURROUNDING_MAP_EXTEND_M | 0 0 | |
| TIMESTAMP_FORMAT | dd/MM HH:mm:ss | |
| TIME_ZONE | ||
| TRAFFIC_VISUAL_MULTIPLIER | 4.0 | |
| WATER_HEIGHT | -20000.0 | |
| WATER_TYPE | CANAL | |
| WEB_ALLOW_LOGIC_EVENT | true | |
| WEB_ALLOW_PARTICIPANT_EVENT | true | |
| WEB_ALLOW_QUERIES | false | |
| WEB_BASE_MAP | SATELLITE | |
| WEB_FRONT_PANEL | -1 | |
| WEB_MAP_CUSTOM_PANEL | -1 | |
| WIND_DIRECTION | 135 | |
| WIND_SPEED_M_PER_S | 5.0 | |
| WIZARD_TIME_MINUTES | -1 | |
| WORLD_REFERENCE_POINT | 0 0 |
